Version 2.0.4 Released
Announcements of general interest
Post by Doug » Wed May 28, 2025 10:53 am
Version 2.0.4 of the Buildbotics Controller software has been released. This release applies to our Buildbotics Controllers that incorporate the Raspberry Pi 4 which have been available since the fall of 2023.
The following improvements are incorporated in this new release:
  • The EM60 VFD now brakes to a stop rather than coasts to a stop. This causes the spindle to stop much faster.
  • Support for the M66 command improved and now provides the ability to pause execution until an i/o input changes.
  • All origins and Cross Origin Resource Sharing (CORS) are now configurable on the SETTINGS->Network page. Unless you are doing applications development, using the Buildbotics Controller, you should leave this setting blank.
  • An improvement was made to the power firmware that prevents damage to the controller that could occur if the 5V power supply becomes overloaded. Overloading of the 5V supply can occur if there are too many devices on the USB connectors or if too much current is drawn from the I/O pins on the DB25 and DB15 connectors.
