Fuling VFD
The purpose of this forum is to discuss interfacing, controlling, and configuring variable frequency drives, especially when connecting to a Buildbotics Controller
No gambling, no profanity, no porn. Treat others with dignity and respect. Posts must generally be within the topical area on CNC machines. Violators will be banned without warning or explanation.
mauroluciobh
Fuling VFD
Post by mauroluciobh » Tue May 03, 2022 11:50 pm
HI,
Has anyone already configured Fuling VFD with Builbotics? I have one DZB 300 series which I'm including the manual. I'd like to configure it using RS-485 communication interface, preferably . If someone can be of any help, please.
I'm attaching the link for the VFD manual below:
https://cncu.co.za/EasyRoute-CNC-Router ... Manual.pdf
Re: Fuling VFD
Post by Doug » Wed May 04, 2022 12:29 pm
Version 1.0.3 of the Buildbotics Controller software supports Fuling VFD’s. Just select it from the pull down menu.
mauroluciobh
Re: Fuling VFD
Post by mauroluciobh » Thu May 05, 2022 12:52 am
Thank you so much
mauroluciobh
Re: Fuling VFD
Post by mauroluciobh » Fri May 06, 2022 9:25 am
I received today my controller with the Onefinity CNC. It is updated, running Version 1.0.9, but I could not find the FULING VFD in the tool configuration list. Is there anything I am possibly doing wrong or missing? (I’ve attached the picture of my screen below)
mauroluciobh
Re: Fuling VFD
Post by mauroluciobh » Fri May 06, 2022 9:41 am
Tool configuration list:
Router (Makita)
Laser (J Tech)
PWM Spindle
Unsupported tools
Huanyang VFD
Custom Modbus VFD
Nowforever VFD
Delta
YL600, YL620, YL620-A VFD
FR-D700
Sunfair
OMRON MX2
Re: Fuling VFD
Post by Doug » Fri May 06, 2022 5:33 pm
We don’t make OneFinity controllers. You need to ask them.
mauroluciobh
Re: Fuling VFD
Post by mauroluciobh » Sat May 07, 2022 1:39 am
HI Doug, thanks for replying.
Acording to Onefinity website: "Our CNC Controller is based on the Buildbotics open sourced platform. Visit the Buildbotics website to learn more: https://buildbotics.com/"
I understand it uses the Builtbotics controller hardware, but might not be running the same exactly software.
Can you please send me a print of the Buildbotic controller software TOOL CONFIGURATION section that shows the configuration used for the FULING VFD or any manual that shows it? I think I can build a Custom Modbus VFD configuration based on that. It for sure would give me some good informations to start with.
Re: Fuling VFD
Post by Doug » Sat May 07, 2022 6:31 am
Sorry, but I do not provide support for OneFinity.
mauroluciobh
Re: Fuling VFD
Post by mauroluciobh » Sat May 07, 2022 8:18 am
I understand now that you don't provide support for Onefinity and don't take any responsibility for it. Fair enough.
Let's just forget I have the Onefinity and just want one information.
Is it possible to provide, according to the Version 1.0.3, Tools Configuration for the Fuling VFD, what parameters I should change (set) on the VFD. I have these example from the Controller Manual for the Nowforever VFD, as the picture below, and just need the same kind of information for the Fuling DZ3B00 VFD.
