Stepper Motor with Brake
jimbobucket
Post by jimbobucket » Tue Apr 12, 2022 3:19 pm
I'm retrofitting a 90's era ISEL Gantry III CNC router. It is not closed loop.
Easy = All 3 motors work and are being controlled by the Buildbotics unit (no closed loop).
Easy = It has limit switches built into all 3 axis', I'm working on rewiring switches to be separate wires instead of being wired in series.
Problem = The Z-axis has a brake on the top of the shaft. The brake is engaged when no power is applied. Per the website/vintage documents online, its looking for 24v to be applied to push the break off. I will need to program it to apply 24v to a specific circuit only while the z-axis is moving.
Stumped = Non of the pins on either breakout boxes go past 10v. Where can i get a switchable 24v pin?
The z-axis is close to self feeding down. So this motor will need the brake.
Or do i scrap this motor and buy something modern.
Will a new motor be any different?
Re: Stepper Motor with Brake
Post by Doug » Tue Apr 12, 2022 3:39 pm
You could connect one of the 5V outputs to a solid state relay like this one on Amazon. Then wire the output in series between your brake motor brake and a 24VDC power supply.
The 5V output pins on the DB25 connector can be controlled with various GCode commands.
