Load1 36v down to 12v
Post by Mick » Tue May 19, 2020 7:23 pm
So I'm upgrading to a 2.2kw water cooled spindle and was thinking of using the load1 output to turn on and off the water pump.
My controller is currently powered by a 36volt power supply
The water pump is 12volt
My thoughts were to run the load1 output to a step down converter as below
https://au.mouser.com/ProductDetail/MEA ... ejlw%3D%3D
Then from the step down 12 volt to the water pump
Will this work?
Any better solutions?
Re: Load1 36v down to 12v
Post by Doug » Wed May 20, 2020 11:15 am
That should work, but something like this would be cheaper, and it is sealed.
https://www.ebay.com/i/254089911666?chn ... 5wQAvD_BwE
I am using one of these for another application and it seems to work fine.
Post by Mick » Wed May 20, 2020 4:56 pm
Thanks Doug
Post by Mick » Sun Jun 14, 2020 10:04 pm
Doug any recommendations for a relay that I can use for the load 1 output which is 3.3volts?
3.3v trigger 36v from the power supply
or
3.3 trigger 24v after the convertor
Solid state relay?
Post by Doug » Mon Jun 15, 2020 10:16 pm
I have been using the SSR40-DD solid state relays successfully on the 3.3V outputs. Here's a link:
https://www.amazon.com/SSR-40-5-220VDC- ... ial&sr=1-2
