Page 1 of 2
Browser/display timeout on longer carves
Posted: Tue Dec 29, 2020 5:23 pm
by JPG963
Is it normal during a carve for the display connected to hdmi to go blank with refresh button. When this happens I cannot view remotely and also lose webcam. Once I go to controller and refresh page I can then access remotely and hdmi displays controller. Is there sleep settings that can be adjusted on the ras pi?
Re: Browser/display timeout on longer carves
Posted: Tue Dec 29, 2020 10:21 pm
What version of software is your Buildbotics Controller running?
Posted: Fri Jan 01, 2021 3:43 pm
by JPG963
0.4.15
Posted: Fri Jan 01, 2021 5:29 pm
It is possible that the Raspberry pi is getting overloaded. Does this occur if you disconnect the camera?
Posted: Fri Jan 01, 2021 8:11 pm
by JPG963
Yes it does. It does not hinder the actual functionality of the running gcode and like I mentioned when refresh is clicked it quickly reloads the controller screen and will stay on. I have not timed how long it takes to "time out" but seems to be going into a sleep mode if there is no movement of the mouse.
Posted: Sat Jan 02, 2021 5:50 pm
I have never seen the controller in this state. Can you post a picture of the screen when it happens?
Posted: Sat Jan 02, 2021 8:39 pm
by JPG963
Here is what is displayed through the hdmi output. When this occurs webcam can not be viewed remotely until refresh is clicked. Does not effect running gcode
Posted: Thu Jan 07, 2021 8:18 pm
by JPG963
Doug wrote: ↑Sat Jan 02, 2021 5:50 pm
Any ideas what may be causing this?
Posted: Tue Jan 12, 2021 6:39 pm
Actually, I have seen this screen before. It occurred when I was running a video stream and running a session on the local console and another session via a wireless network. The wireless connection was through a wifi dongle.
Does this situation sound familiar to you?
Also, can you post the gcode program that you are running when this happens?
Posted: Fri Jan 15, 2021 8:13 am
by JPG963
This happens on every gcode file I run that is over 15 minutes cut time and happens even with just a direct connection to HDMI. It seems like there is a sleep setting set incorrectly on the raspberry Pi that is pausing the browser if there is no mouse/input device movement. Like I said before it does not affect the file being run but I lose the screen and have to click reload to get it back up. During the screen time out message I also cannot view remotely or control/estop the unit remotely. I am running a wifi dongle. Is there usb sleep settings that may be switching off after say 15minutes of inactivity.
