G53 no fit error
wupinstick
G53 no fit error
Post by wupinstick » Mon Jun 28, 2021 4:13 am
I created a tool change script (see below) and it seems the G53 command causes a no fit error on the Z axis. the program still runs fine. Should I be going about this differently? My Z limit switch is set to max travel. So when I home the machine the axis are X0 Y0 and Z3.347.
EDIT: looks like this issue has already been documented here
viewtopic.php?f=5&t=226
below are my scripts.
(Runs at program start)
M70
G20
M0 (MSG, Attach probe)
F10
G38.2 Z-3
G92 Z0.059
G53 G1 Z3.3
M0 (MSG, Remove probe and Install dust boot)
M72
(Runs on M6, tool change)
M70
G20
F10
G53 G1 Z3.3
G0 X0 Y0
M0 M6 (MSG, Change tool and attach probe)
F10
G38.2 Z-3
G92 Z0.059
G53 G1 Z3.3
M72
(Runs on M2 or M30, program end)
F10
G53 G1 Z3.3
M2
XCross
Re: G53 no fit error
Post by XCross » Thu Jul 08, 2021 2:32 am
The issue is documented https://github.com/buildbotics/bbctrl-f ... ssues/297
@Doug - please priorize this request
Thx
Martin
