Limit switch pull-up?
Posted: Sat Mar 05, 2022 7:37 am
Hi,
I'm, having some issues getting my limit switches to work correctly for my custom machine. I have PNP NO inductive proximity switches in both directions (min and max) on all three axes. They are supplied by +24V and share ground with the buildbotics controller which I bought a few weeks back. I read in the latest manual that the limit switch inputs can go up to 50V without damaging the controller so these switches are NO with 0V for not engaged and +24V for activated.
Now, the problem is that there seems to be some voltage offset somewhere that makes the output of my limit switches be at around 0.8 V when they are not activated/engaged and this is above the logic voltage level threshold for this type of input according to the buildbotics manual v1.1.
Also, when I measure the voltage between ground and the motor # max/min pin without any switch connected I measure 3.2 V, which leads me to belive these inputs are pulled-up by the controller? SInce the inputs are pulled up: Is this set by the microcontroller or the raspberry or are there soldered resistors on the controller PCB?
I see the point of having a pull-up resistor if a classic microwitch is used, but not really in any other situation..
Any insight would be very helpful.
Thx,
Adrian
Thx,
Adrian
