Web UI component toggling
Post any suggestions that you have for new features and enhancements for the Buildbotics Controller here.
d8ad0rk
Post by d8ad0rk » Tue Jan 05, 2021 6:37 pm
I added a separate display with another raspberry pi in kiosk mode so i can see the simulation\status of the cut from across the garage. The issue is that I would like to toggle components off on this display and only retain things like the position information, machine running state table, the Auto tab with the Path View size large.
I looked at the code base for this and it is beyond my skillset to add another page template and do the build to generate it. Not sure how complex a customizable display would be from a toggle components on or off would be. Additionally it would be nice on a remote display to not pop modal dialogs as there are no input devices on my remote kiosk display.
Joe
Site Admin
Contact:
Re: Web UI component toggling
Post by Joe » Fri Jan 15, 2021 9:09 pm
We don't have any easy way to support this right now. As you noted, it's Open-Source so you could change the code. Sorry I cannot help more than that.
