Speed and Feeds override during Job
Post any suggestions that you have for new features and enhancements for the Buildbotics Controller here.
BiuTse
Post by BiuTse » Sun Apr 26, 2020 11:54 am
Would be nice to change speed during a job.
Re: Speed and Feeds override during Job
Post by Doug » Sun Apr 26, 2020 5:14 pm
Adjusting feed rate on the fly is pretty difficult. But, adjusting spindle speed is not too difficult. What would you think of being able to adjust spindle speed but not feed rate as an interim feature?
BiuTse
Post by BiuTse » Wed Apr 29, 2020 11:21 pm
Hmm Spindle speed is not a problem now because I still have to use a separate powersupply for the PWM for my spindle. Still didn't get the PCB we spoke about from China.
But yes this would be already a step in the right direction
Post by Doug » Thu Apr 30, 2020 2:38 pm
Thanks for the input. Maybe we can get the ability to adjust spindle speed on the fly added soon.
Bob916
Post by Bob916 » Thu Jan 20, 2022 12:33 pm
I would be more interested on having more control over the feed rate on the fly. Is there anything in the works toward this?
donramsey
Post by donramsey » Sun Feb 20, 2022 7:02 am
Changing the feed rate during a run would be a great addition.
DainBramage1
Post by DainBramage1 » Fri Jun 02, 2023 10:22 am
Is the inability to adjust feedrate on the fly a hardware challenge or software? Would it be possible to make it happen by using GSender or some other gcode sender? I haven't had my Onefinity Journeyman long, but I already miss that functionality!! Thank you.
-- Brad
Post by Doug » Sun Jun 04, 2023 10:31 am
It is a soft issue. It is not feasible to integrate GSender.
vincent_konglomerat
Post by vincent_konglomerat » Fri Jul 04, 2025 10:44 am
would also be very interested in adjusting the feed rate on the fly! That would be a really nice feature for buildbotics! Any chance this is achievable nowadays?
Maybe its easier to implement if it acts more as a multiplier so people can only adjust a percentage value/slider but not the actual feedrate?
liqidtensn
Post by liqidtensn » Mon Aug 11, 2025 5:10 pm
With my CNC router being used as a training tool for new students, having a feed rate override or at least a slider bar that is a multiplier would be great to help quickly adjust things when the students get the feeds and speed wrong.
I have used many different software in the past for my CNC machines and they all have this feature. If you are having an issue with implementing the code to make this work, might I suggest look at some of the Open Source CNC control code to find out how they did it?
OpenBuilds has their code on GitHub. https://github.com/OpenBuilds/OpenBuild ... ree/master
