Wanted to know
Use of profanity is prohibited.
Gambling is prohibited.
Sexual or pornographic material is prohibited.
Illegal activities of any kind are prohibited.
The moderator reserves the right to deny or delete any content without notice.
				bhoward253
Wanted to know
I want to add this to a Harbor freight mini mill that has all the add on for a cnc mini mill just wanted to know before I buy. I think it will work but just checking, I think I can put it together. I am new to this so be gentle.
						Re: Wanted to know
Welcome to the forum. I'll need a few more specifics about your machine. I think I can best help you via the phone. I left you a phone message to call me back.
						Re: Wanted to know
I took a quick look at it. There doesn't seem to be any documentation on the interfaces. I'll assume that the motors are bipolar steppers and that they will work fine. The spindle control is through a pwm interface. There is no indication of the voltage amplitude that is required for the pwm signal. The BB controller puts out a 3.3 volt signal, so you might have to add a level shifter to make it compatible with their spindle.
