Speed and Feeds override during Job
Would be nice to change speed during a job.
						Re: Speed and Feeds override during Job
Adjusting feed rate on the fly is pretty difficult. But, adjusting spindle speed is not too difficult. What would you think of being able to adjust spindle speed but not feed rate as an interim feature?
Hmm Spindle speed is not a problem now because I still have to use a separate powersupply for the PWM for my spindle. Still didn't get the PCB we spoke about from China.
But yes this would be already a step in the right direction
Thanks for the input. Maybe we can get the ability to adjust spindle speed on the fly added soon.
I would be more interested on having more control over the feed rate on the fly. Is there anything in the works toward this?
Changing the feed rate during a run would be a great addition.
				DainBramage1
Is the inability to adjust feedrate on the fly a hardware challenge or software? Would it be possible to make it happen by using GSender or some other gcode sender? I haven't had my Onefinity Journeyman long, but I already miss that functionality!! Thank you.
-- Brad
It is a soft issue. It is not feasible to integrate GSender.
				vincent_konglomerat
would also be very interested in adjusting the feed rate on the fly! That would be a really nice feature for buildbotics! Any chance this is achievable nowadays?
Maybe its easier to implement if it acts more as a multiplier so people can only adjust a percentage value/slider but not the actual feedrate?
				liqidtensn
With my CNC router being used as a training tool for new students, having a feed rate override or at least a slider bar that is a multiplier would be great to help quickly adjust things when the students get the feeds and speed wrong.
I have used many different software in the past for my CNC machines and they all have this feature. If you are having an issue with implementing the code to make this work, might I suggest look at some of the Open Source CNC control code to find out how they did it?
OpenBuilds has their code on GitHub. https://github.com/OpenBuilds/OpenBuild ... ree/master
