Browser/display timeout on longer carves
Re: Browser/display timeout on longer carves
Post by Doug » Fri Jan 15, 2021 9:43 pm
I am not aware of a timeout setting on the Chromium browser.
I just loaded a program on my machine. It takes 29 minutes and 30 seconds to run. I ran it twice with no failure. In both cases, I had a wifi dongle plugged in. On the first run, I did not have a remote connection. On the second run, I had a remote connection from another desktop computer on the same network.
I think we can solve this more quickly if you call me at 707-559-8539. We can post the solution when we figure out what is causing the problem.
JPG963
Post by JPG963 » Sat Feb 13, 2021 8:40 pm
Doug,. I believe I have solved my issue. I was using an old LCD TV as a monitor which I have replaced with a 23" Dell 2314T touchscreen monitor. Since then I have had no issues with the browser going into sleep mode. Unsure if it was due to voltage draw or communication through the HDMI...
Post by Doug » Sun Feb 14, 2021 12:52 pm
That's good to know. Thanks for reporting the result.
