SIPUN SPVF-2.2G-S2 Variable Frequency Drive
The purpose of this forum is to discuss interfacing, controlling, and configuring variable frequency drives, especially when connecting to a Buildbotics Controller
No gambling, no profanity, no porn. Treat others with dignity and respect. Posts must generally be within the topical area on CNC machines. Violators will be banned without warning or explanation.
leadgtr7
Post by leadgtr7 » Fri Jan 28, 2022 9:11 am
Does anyone know if this VFD is supported?
https://www.amazon.com/dp/B0972MCVV5/?c ... _lig_dp_it
I got the manual from the vendor and it looks like it would work by setting (found on page 56 of attached manual)
P0-00 to 5: 9600 baud
P0-01 to 0: No parity
P0-02 to 1: Local Address of 1??
I'm just not sure how to setup all the functions and what not for the custom MODBUS option in tool settings
any help would be great as this looks like a rather good VFD
VFD-0.75-3.7K User Manual-20210126.pdf
(3.38 MiB) Downloaded 4653 times
Re: SIPUN SPVF-2.2G-S2 Variable Frequency Drive
Post by Doug » Sat Jan 29, 2022 10:42 am
We do not currently support this VFD.
I took a look at the manual and it appears that they only support a multiword read command. This means that the read format does not appear to be compatible with the read format in the Buildbotics Controller. If this is true, then it is doubtful that we could make the interface work without a software change in the BB Controller.
Post by Doug » Wed Feb 02, 2022 6:13 pm
After further review, I think we do stand a good chance of getting this going. I think the multi-word read issue is a non-issue.
