V1.0.0 BROKEN
wilsonedw
V1.0.0 BROKEN
Post by wilsonedw » Tue Mar 01, 2022 1:48 pm
I just downloaded V1.0.0 and it is a hot mess for me, I can run a program as long as it's off a stick drive that I put in the back WIFI does not work now.
Permenant message warning COMM SRC/modbus.c:257 repeat is counting up, message:0 OK: modbus: unexpected response to read
no Gcode at all when running program, Gcode editor does not show anything when a program is loaded
I would like to reload but no wifi can you provide me with a fresh install of the software so that I can do a manual upload.
wilsonedw
Re: V1.0.0 BROKEN
Post by wilsonedw » Tue Mar 01, 2022 5:01 pm
I found a V1.1.0 file on one of the boards, reloaded and everything that I have worked with seems to be working correctly except I still have the error Permanent message warning COMM SRC/modbus.c:257 repeat is counting up, message:0 OK: modbus: unexpected response to read
Re: V1.0.0 BROKEN
Post by Doug » Wed Mar 02, 2022 7:47 am
Here are a few questions:
  • Do you have a VFD?
  • If so, what type?
  • What type is assigned on Settings->Tool page?
  • Are errors counting up in tool page?
wilsonedw
Re: V1.0.0 BROKEN
Post by wilsonedw » Wed Mar 02, 2022 5:28 pm
I do not use the VFD function, I adjust it using the rheostat.
if that is the error that I am getting we are golden.
