Create a Desktop Shortcut to the Controller
Post by missionarymike » Tue Apr 05, 2022 6:49 pm
Tired of typing in the ip address of the controller each time you need to remote in to it?
Here is a desktop shortcut you can use!
BuildBotics Controller.zip
Shortcut Zip File
(309 Bytes) Downloaded 1981 times
I had to compress the file so the file extension wouldn't trigger an error.
All you have to do is download the folder, unzip it, save the shortcut to your desktop, then right-click on it and update the IP address so it will link to your controller.
Good luck!
