RS485 Communication Problems
The purpose of this forum is to discuss interfacing, controlling, and configuring variable frequency drives, especially when connecting to a Buildbotics Controller
No gambling, no profanity, no porn. Treat others with dignity and respect. Posts must generally be within the topical area on CNC machines. Violators will be banned without warning or explanation.
drmartin
Post by drmartin » Tue Jul 16, 2024 9:13 pm
I’m running v1.0.3 of the controller software on a version 15 main board. The VFD is a H100-3.7S2-1B made by Huajiang. It uses the same Modbus addresses and values as the H100 on the Tool Configuration window. I’ve verified this by using a Waveshare USB to RS485 adapter and Modbus master software and reading and writing to the various addresses. When the Buildbotics controller is connected to the VFD and correctly configured the status connection indicates “CRC error” most of the time with an occasional “OK”. If I send M03, M04, M05, or S commands from the MDI screen sometimes it works but most of the time it doesn’t. If I configure the USB to RS485 as a Modbus slave and connect it to the Buildbotics controller this is the data I see in the slave software log.
>4:36:25 PM: RX: 7f 3e 3f fe
>4:36:25 PM: RX: 7f 3e 3f fe fe de 6c fe
>4:36:25 PM: RX: fa f2 fe ea fe fa ae a4 fe
>4:36:25 PM: RX: 7f 7e ea fe fa ae a4 fe
>4:36:26 PM: RX: 7f 7e ea fe fa ae a4 fe
>4:36:26 PM: RX: 01 03 00 05 00 01 94 0b
>4:36:26 PM: Sent data: Function code:3.
>4:36:26 PM: TX: 01 03 02 01 90 b9 b8
>4:36:26 PM: RX: 01 06 02 00 00 00 88 72
>4:36:26 PM: Received address is not within viewable range, Received address:512.
>4:36:26 PM: TX: 01 06 02 00 00 00 88 72
>4:36:26 PM: RX: 01
>4:36:26 PM: RX: 7f 3e 3f fe fe de fe
>4:36:26 PM: RX: 7f 3e 3f fe fe de 6c fe
>4:36:27 PM: RX: 7f 3e 3f fe fe de 6c fe
>4:36:27 PM: RX: fa f2 fe ea fe fa ae a4 fe
>4:36:27 PM: RX: 7f 7e ea fe fa ae a4 fe
>4:36:27 PM: RX: c0 60 05 00 01 94 0b
>4:36:27 PM: RX: 01 03 00 05 00 01 94 0b
>4:36:27 PM: Sent data: Function code:3.
>4:36:27 PM: TX: 01 03 02 01 90 b9 b8
I’m seeing good 03 reads and 06 writes to slave ID 01 but I’m also seeing a lot of extra junk. I’m using about 2 feet of the green pair of a cat 5e cable. I’ve tried adding a 100ohm termination resistor and using a longer cable. I've also tried changing the baud, parity, and bus id settings.
Any thoughts on what might be causing it or other things to check?
Re: RS485 Communication Problems
Post by Doug » Wed Jul 17, 2024 3:33 pm
Try reversing the RS-485 pair.
drmartin
Post by drmartin » Wed Jul 17, 2024 5:45 pm
That fixed it. Thanks Doug.
samlevy0515
Post by samlevy0515 » Tue Feb 24, 2026 9:25 pm
I gave that a try and it completely fixed the issue.
Precision planetary gearbox for demanding motion.
