Software version 0.4.13 is available. It provides the following improvements:
* The Buildbotics Controller can now control OMRON MX2 Variable Frequency Drives. It has been added to the tool-type pull-down menu on the "Tool" page.
* Error handling during WiFi configuration has been improved.
* Video performance has been improved. You will now experience lower latency and higher frame rates when streaming video from your Buildbotics Controller.
* Up to four clients can now view the video stream from the Buildbotics Controller simultaneously.
* Axis bounds GCode variables #<_x_min>, #<_x_max>, etc. are now accessible from GCode programs and from the program-start, tool-change, and program-end text boxes on the "Settings" page.
* You can now configure junction acceleration from the "Settings" page. This allows you to specify the maximum acceleration allowed when rounding corners.
* A problem existed that prevented users from doing manual software "Uploads" from OSX computers. This has been fixed.
* Cameras that do not support MJPEG format video are now ignored.
						0.4.13 released
No profanity, No gambling. No porn. No illegal activity of any kind. Violators will be removed without notice.
